OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to announce that the Anidees AI-6 V2 case range will be landing exclusively with Overclockers in June. The AI-6 V2 has made significant improvements on the old AI-6 chassis, including improved watercooling support, a bigger side window, addition of a card reader and fan controller plus other tweaks and improvements to make a great case even better.
Stock should be available at the end of June, so get your preorders in now!
Anidees AI-6B V2 Midi Tower Case - Black Side Window @ £112.99 inc VAT
The AI-6B V2 expands on the popular AI-6 chassis and adds a host of new improvements to improvement various aspects of the chassis. Significant improvements have been made with the watercooling support, meaning that there is now support for 240mm radiators on the front and top of the chassis along with the bottom as per the original design.
The I/O panel has had a rehaul, with an SD Card Reader & a fan controller being introduced for greater functionality. In addtion, the side window size has been increased significantly in order for you to show off your build with pride.
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior, with a brushed aluminum centre. In between lie a set of stealthy and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Specifications
- Dimensions (L x W x H): 527 x 207 x 509
- Material: Steel, Aluminum
- Weight: 11kg Net, 12.5kg Gross
- Colour: Black
- Form Factor: ATX, Micro ATX, Mini-ITX
- Cooling: 7 locations - Front: 140 / 120mm fan x 2 (140mm x 1 included), Rear: 120mm x 1 (included), Top: 140 / 120mm x 2 (optional), Bottom: 140 / 120mm x 2 (optional)
- Liquid Cooling Support: Front - Up to 240mm, Rear - Up to 120mm, Top - Up to 240mm (max thickness 58mm), Bottom - Up to 240mm (with removal of HDD cage)
- Filters: Front & Back
- Large Transparent Side Window
- Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 9 x 2.5 inch (internal) - SSD Cage behind MB tray
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 7
- I / O Panel: SD Card Reader, Fan Controller, 2x USB 3.0 / 2 x USB 2.0 / 1x each Audio In / Out
- Maximum graphics card length: 280mm / 428 mm (with HDD cage removal)
- Maximum CPU cooler height: 177mm
- Features: Elements made of brushed aluminum, Cable Management, HDD and power supply decoupling, Removable hard disk cages.
Only £112.99 inc VAT.
ORDER NOW
Anidees AI-6B V2 Midi Tower Case - Black @ £104.99 inc VAT
Specifications
- Colour: Black
Only £104.99 inc VAT.
ORDER NOW
Anidees AI-6B V2 Midi Tower Case - Black Noise Dampened. @ £112.99 inc VAT
Specifications
- Colour: Black
- Noise Dampened Interior for silent operation
ORDER NOW
Specifications
- Colour: Black
ORDER NOW
Specifications
- Colour: Black
ORDER NOW
Specifications
- Colour: Black
ORDER NOW
