Hi all,
I've recently completed my first PC build, all went smoothly, it works and have run in to no trouble so far with it.
I wanted to swap out the front fans in the Anidees cube for some Thermaltake ones which I have just done but the four I removed from the front I have now put in the top plus an extra one at the bottom as I had a spare...10 fans in total plus the CPU cooler
The Ryzen software says it's idling at around 32 degrees but if I have all cores flat out it jumps up quickly as expected but it's not going that high, may be to around 55 degrees if I just run Cinebench.
Just wanted to check if what I have done is ok or if any of the fans should be facing a different way....
Some photos attached, any help would be great..
Apologies for the sideways pics
Thanks
Thanks
