26 Oct 2008 at 21:50 #1 stryder stryder Associate Joined 24 Apr 2003 Posts 976 Location greater manchester do you have to have vista ultimate to run an animated background or will they work with vista basic?
26 Oct 2008 at 21:52 #2 mr.sly mr.sly Soldato Joined 25 Jul 2006 Posts 3,877 Only in Vista Ultimate if you mean the Dreamscene wallpapers. Although I believe VLC can help you achieve the same goal.
26 Oct 2008 at 21:57 #3 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK I think there's a "patch" to get it working on Home Premium, i'm not sure about Basic though.
26 Oct 2008 at 22:01 #4 stryder stryder Associate OP Joined 24 Apr 2003 Posts 976 Location greater manchester thanks
27 Oct 2008 at 10:56 #5 scooby555t scooby555t Associate Joined 20 Dec 2006 Posts 2,132 Location aberdeenshire the patch does work i have it working now home prem retail
27 Oct 2008 at 11:05 #6 Wizardskills Wizardskills Associate Joined 25 Feb 2007 Posts 2,067 Location Bedfordshire Will this patch work on vista business? If so, link pls
27 Oct 2008 at 11:09 #7 Snakedoctor Snakedoctor Soldato Joined 13 Sep 2007 Posts 3,951 only works for 32 bit and it's naughty.
27 Oct 2008 at 11:14 #8 bledd bledd Don Joined 21 Oct 2002 Posts 46,882 Location Parts Unknown plus, dreamscene is crap and buggy anyway, don't bother
27 Oct 2008 at 11:53 #9 swinnie swinnie Soldato Joined 30 Apr 2007 Posts 3,095 Location Kent bledd. said: plus, dreamscene is crap and buggy anyway, don't bother Click to expand... This. Plus, animated wallpapers are very annoying too.
27 Oct 2008 at 17:04 #10 scooby555t scooby555t Associate Joined 20 Dec 2006 Posts 2,132 Location aberdeenshire works on x64 as well
27 Oct 2008 at 17:46 #11 Antar Bolaeisk Antar Bolaeisk Soldato Joined 19 Dec 2006 Posts 9,262 Location Saudi Arabia né Donegal Or create an animated .gif file and set that as the background. I remember doing this on our old 98 machine and it was brilliant for about 5 mins after which it got old very quickly.
