Animated GIF Testing
15 Sep 2008
Test 01, 540x960, 70MB
embed
Was lurking in the test section and came across this... it's mesmerising. I must've watched it 20 times now :cry: . Out of interest (if you read this), what coolant are you using?
I had notifications switched on so saw your comment :) .
The coolant is just simple distilled water and Halfords engine coolant. The reason for it being all floaty like at the beginning of the clip is that I'd just added more distilled water on top of the coolant in the reservoir and it was yet to mix properly. Sadly it doesn't look like that anymore as it's all mixed and all the air is out of the tubing.
You can see more on my system using the link in my sig or in case you have signatures switched off, click here.
