Annoying beep
13 Nov 2007
Aberdeen
Everyone has that normal one off bleep when the computer starts. Since I started overclocking I now have another much louder, longer beep that follows it. Drives me nuts. How do I get rid of it? My speakers are turned off, it's definately coming from the motherboard or something in the tower.
Gigabyte GA-P35-DS3L Intel P35 (Socket 775) PCI-Express DDR2
E2180 (2.Ghz)overclocked @3.1
2GB RAM
250GB hard drive
I don't have the manual with me at the moment. It's 100 miles away in my parents house.
Go into the BIOS and identity what BIOS Manufacturer your mobo uses i.e. AWARD etc.
Then head off to www.bioscentral.com and cross reference the BIOS with the number and type of bleeps you are getting. This will tell you what the problem is.
However, A short single bleep normally indicates that your system has passed basic diagnostics, but this could be different between type of BIOS.
This is weird. It is an Award one. So here are the codes:
http://www.bioscentral.com/beepcodes/awardbeep.htm
However, it doesn't appear to be any of them! It's one long beep (3 seconds) which is then proceeded by the standard one bleep it always had. Besides the only thing that has changed is when I overclocked the CPU yesterday. The two CPU bleeps there don't match that.
I ignored it at first because I knew what I was doing was fine and the temperatures are fine (low 30's idle). I know it is because of the changes to the CPU, however there is nothing wrong with it. Still it just doesn't sound right....
Ahh just spotted it in submissions.
"Continuous beeping, each lasting about three seconds. The beeping does not stop. Seems to be CPU related. Submitted by baders."
So, lol, what do I make of that. ??!!
Undid the overclocking. Restarted the computer twice. Both times got it. That really is head scratching.
Anyway, I have put the CPU back to how I had it (overclocked at 3.1).
So what is causing that bleeping.... I haven't touched anything indside.
