I'm trying to resuscitate an old computer.
Put a windows 7 disk in and got to the install menu and got an error. Checked my cables and I'd not plugged the hard drive sata cable into the motherboard. Dummy mistake but easily fixed!
Restarted and now I can't even get to the install menu. I get the "press any key to boot from cd" but then it gives me the bootmgr is missing error.
The keyboard is then unresponsive and I can't press curl alt del to restart or do anything.
Any ideas what I can try to get it to boot the cd? It worked fine before I plugged the hard drive in. No idea about the hard drive as I bought it off here. But surely even if faulty I should get to the installation menu?
