Annoying boot up problem!
18 Jul 2005
Planet Earth...Somewhere
This has been happening more and more often lately and now it tends to be every other boot.
I power the wifes pc up-and as it starts to POST it comes up with a error.
It usually takes 3 or 4 resets before it stops with the error and boots normally.
The error is:
BIOS ROM CHECKSUM ERROR
Detecting floppy drive A media...
INSERT SYSTEM DISK AND PRESS ENTER.
I dont know why its doing it,if you could shed any light it would be appreciated.
Its the wifes 2.4Ghz celery-with some cheap generic mobo;)
Thanks in advance!
I had problems like this a while back and it was the motherboard battery.
Worth a try.
*EDIT* If that doesn't work then you could be looking at a faulty bios chip.
Dan
