Annoying chipset cooler
17 Jun 2005
Cambridge, UK
Hello guys,
I have moved all my components to a new Lian Li PC-7 Plus case. My motherboard is a MSI Neo4 Platinum rev1.0 and the problem is that my graphics card (a 7950GX2) goes over the chipset cooler.
I have seen some of the passive solutions provided by Zalman but I need something that has a lower profile than the ZM-NB47J or ZM-NBF47.
Any ideas anyone?
Gabriel
aye, i have one of those myself... on my broken motherboard...
It was great whilst it was working, silent and knocked about 5*C off my idle/load temps
Ezyryder said:
itS a lot of money :(
No, it's not. It's a bargain. It's massive, passive and does the job properly. Once you get it you'll realise what a complete work of art it is. The Zalman coolers are relatively cheap, but they are just aluminium castings. This a proper 70mm twin heatpipe cooler. You could probably cool your CPU with it, so not only will you get to play with that 7950GX2, but the overclocking should be easier too. Big win all round. And OcUK have pretty aggressive pricing on Thermalright at the moment.
Ezyryder said:
I will probably get it. There is a local shop where I live that sells them for 15 quid :)
Do they have help forums too? ;)
C'mon dude! OK - so you're not going to buy it from OcUK, but you don't need to blab about it.
vairo said:
lol :D ehehe,dunno why but since i joined this forum and ordered first item from overclocker.cu.uk i never ever used any ather store ! :D
I will buy first from OcUK, but if the price is silly or they are out of stock, or they just can't/won't/don't stock what I want I'll go elsewhere. I try not to brag about it too much though.
Hi guys
Asked Thermalright and they have told me my mobo is not compatible with the HR05 SLI or the other one.
Any other solutions?
About OCuk, I buy here most of the time (bought my lian li, dvd drive, computer parts for the past 3 times) I am only going to order something from next door because I can walk in and get it!! :)
