annoying chrome issue and __dopostback
27 Mar 2003
Hi all,
just wondering if someone can help me with a asp.net website that I have built.
here is an example of the site:
http://link.zibrantallocations.com/N3ecg
Now in ie7,8,9, firefox, safari the site loads fine. (it should load up a google map page with 1 venue, 7 hotels and then give you the ability to book a hotel room)
In Chrome it seems the javascript that I use to do the client side postback __doPostBack('control name','') stops working.
does anyone know of a quick fix for this issue as it is causing me a lot of problems and have already wasted several days trying to fix it with no success.
the bit of javascript concerned is:
Code:
 if (hiddenSelectedFieldHotel != null)
                hiddenSelectedFieldHotel.value = selectedHotelID;
                hiddenSelectedCheckinField.value = document.getElementById("<%=  RadDatePickerArrival.ClientID%>").value;
                hiddenSelectedCheckOutField.value = document.getElementById("<%= RadDatePickerDeparture.ClientID%>").value;
                hiddenFieldRooms.value = document.getElementById("<%= RadComboBoxRooms.ClientID%>").value;
//__doPostBack('<%= RadAjaxPanelHotelMain.ClientID %>', ''); <== This is the line of code where the system seems to fail.
            else
                alert("Hidden Field Not found. Something has gone wrong");
Thanks in advance for any help on this.
