Annoying copying to problem
12 May 2011
Southampton
I find myself copying GOG game installers onto USB sticks quite a lot for transfer onto old PCs, as well as drivers and stuff. However when I copy something, some of the time it will come up with a prompt saying "are you sure you want to copy this file without its properties" but it'll take a good 90 seconds of Copying at 0% before this message flashes up. If I leave a bunch of files copying unattended, it might get halfway through and then stop as the next file in its list "doesn't have its properties" so I come back to the PC and the transfer is only half done.
Is there a way I can disable this message, or make sure my files keep their properties?
pretty sure theres a way to set your default answer to yes
but cant for the life of me remember how at the moment
other options may be
format the usb as ntfs not fat/fat32
or a 3rd party file copy software like teracopy may have
an option to disable the popup or answer it for you
Before copying you could try selecting all the files and adjusting their properties so that they all have some properties to be copied.
Is it possible that if it’s old games the file predate having properties that the OS is looking for ?
