Annoying crisp noise
28 Apr 2004
Since a few days my computer speakers are making annoying crisp noise. It happens everytime I play a sound. I've plugged earphones and I still can hear that noise.
When a music is playing and I push Pause, the sound continues, but stops when I press Stop.
Here's a sample of the sound from my speakers recorded from my mobile, quality isn't the same though:
Play with Real Player
What is causing this?
hitmann said:
Turned out to be only on my computer, so I've edited the post.
Any help guys?
That's a very odd noise :confused:
Could be any number of things I guess.
Check for a loose connection on your speakers, or try another set of speakers if you can.
What does your setup consist of?
