Hi all when starting doom 3 I get this annoying error all other games work fine, FEAR, HL2, BF2 etc.
DOOM 1.3.1302 win-x86 May 12 2005 10:40:52
2009 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
256 MB Video Memory
Winsock Initialized
Found interface: {E874BCA9-FD52-4782-834D-F686F2910896} Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller - 0.0.0.0 NULL netmask - skipped
Found interface: {ACE3B45D-B9D5-4162-9E58-DBEB63D13636} NVIDIA nForce Networking Controller - 192.168.1.3/255.255.255.0
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game00.pk4 with checksum 0x29cdb978
Loaded pk4 C:\Program Files\Doom 3\base\game01.pk4 with checksum 0xe9d5adcf
Loaded pk4 C:\Program Files\Doom 3\base\game02.pk4 with checksum 0x80401dd2
Loaded pk4 C:\Program Files\Doom 3\base\game03.pk4 with checksum 0x351c23e8
Loaded pk4 C:\Program Files\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Program Files\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Program Files\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Program Files\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Program Files\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Program Files\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Program Files\Doom 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 C:\Program Files\Doom 3\base\pak007.pk4 with checksum 0x666bdb3c
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak007.pk4 (38 files)
C:\Program Files\Doom 3\base\pak006.pk4 (48 files)
C:\Program Files\Doom 3\base\pak005.pk4 (63 files)
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game03.pk4 (2 files)
C:\Program Files\Doom 3\base\game02.pk4 (2 files)
C:\Program Files\Doom 3\base\game01.pk4 (2 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5206 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Pc has played doom 3 before with absolutely no problems, have a fairly up to date system so def not specs.
Have latest nvidia drivers, and doom 3 patch. any ideas?
Thanks all
256 MB Video Memory
Winsock Initialized
Addon pk4s:
execing editor.cfg
execing default.cfg
...initializing QGL
...calling CDS: ok
sound: STEREO
Thanks all
