- 10 Sep 2008
- Bangor, Northern Ireland
Ive had enough, over the past month my car has developed a squeaky rattle from inside the drivers door. Very loud and annoying, and any mild bumps in the road set it off.
When i open the door it does a single squeak impling its part of the door opening mechanism, but when i pull on the door handle when the door is already open, the squeak isnt there.
Would anyone know which part i need to tighten/grease whatever before i take the door card off and have a rummage? Im not a car expert by any means so be gentle!
Thanks
Ninja - Car is a Seat Leon Mk2
Thanks
