Annoying Error Message
24 Mar 2006
Right, thought id try to sort all my problems out at once :p
Anyway, when I shut down my computer i get this same message every time. It also appears after i have booted up. If i click Cancel the message goes away.
Its just annoying really...
The drive it refers to is my floppy disk drive which has never been used. Could this be the problem? But why does the computer want to read drive A in the 1st place? :confused:
Thanks
You running NOD32 by any chance?
Found a link to a problem with NOD32 when googling for info on this. It apparantly scans the floppy disk drive when you are shutting down and causes this error. If you use NOD32 then I would disable that.
That is correct :)
Edited my post above, included the info :) Something to do with NOD32 scanning the floppy when you shut down, I don't have it myself unfortunately on Vista so I can't check for where the option is, but I'd check around the program for disabling floppy drive scanning and seeing if that helps :)
Had a look at scheduled tasks in NOD32.
The last two tasks look like they could have something to do with it. I shall disable these and see what happens.
Does anyone know if these tasks are needed in any way? Or are important?
