Annoying Fire Fox problem.
30 Jul 2004
East Sussex, UK
Howzit Guys,
Well, I have a small FF problem, that I forgot how I fixed last time.
I have one bookmark in the tab at the top. I don't want it there, but if I remove it. The screen constantly jumps!! :( :mad:
How did I fix this last time? Anyone?
What version of firefox are you using? I thought this problem was sorted now. Iirc removing the bookmarks toolbar fixes this.
If I remove those book makrs, the screen jumps a lot. :(. Using latest FF as well, so dont understand it at all!!
Ice On Fire said:
Howzit Guys,
Have you got theme xp or some sort of windows skins installed?? I had the same thing where FF screen flicked every few seconds, took theme stuff off and it was fine?
Hope this helps! ;)
I had a similar problem and didn't know how to overcome it, until I installed the latest version of Firefox. I don't think it is your Windows theme though, since I had the basic Luna theme when I had that problem. :)
Ice On Fire said:
Yes, i have a Windows Theme applied. But I don't want to remove it...I like it..:(
Have you tried disabling your custom XP theme, say back to Classic Style, to see if FF still jumps around? If it stops then you know what your problem is, if not then its something else.
It was the problem. :(
Thanks for the help guys. :cool:
