So, my computer makes this really annoying high pitched noise that I don't quite know how to describe. I have included a video that shows the problem. The noise is not normally as constant as that, I think it was because I was recording. The problem is fairly unnoticeable when not doing anything, just comes up in bursts. However when I do something like move my mouse or scroll a webpage the problem is more noticeable (the bursts of noise in the video are when I move my mouse). It is also worth noting that the noise can actually be heard without headphones, it is actually a physical noise as well as coming through digitally.
I would say the the noise is linked to the HDD, especially due to the fact it can be heard coming from the inside of my PC as well as digitally. Maybe some kind of grounding issue? I am really stumped. Would a new HDD solve the problem? It really ruins my experience of music and gaming. The headset I'm using is a Roccat Kave. I will try moving the control bit further from the computer to see if it helps as it is prone to picking up interference. Here is the video anyway:
