- 23 Sep 2008
Running My Karma bay on an eclipse 62 case with a Yate loon d12sh installed.
The problem is the filter that sits in front of the fan. When i use the metal clips provided they hit the fan, stopping it from spinning. So i got rid of those and the fan works.
However the filter is now being pulled into the fan, not enough to stop it spinning but just enough to make a very annoying clicking sound as the filter brushes it.
I was thinking I could get a filter that might mount inside the case behind the fan (such as the akasa 120), but thought this would block airflow, or maybe stop the screws from securing the fan to the Bay
Just wondering if anyone had similar problems/solutions.
Cheers!
Cheers!
