Could use advice if anyone can think of anything...
This relates to 4Gb of Corsair Dominator DDR2 (2x2gb) PC2 8500 C5 5-5-5-15. Motherboard is a Asus P5Q-E running the latest BIOS.
The computer has been running fine since the end of April when it was built.
Over the last couple of weeks it's begun randomly crashing/restarting.
I ran memtest a few days ago, and all tested OK. I went on to try a load of other things, but I couldn't get to the bottom of the problem.
I tried memtest again today, and it's failing, consistently, at 42% of the first test - every time.
Either of the modules on their own test perfectly in either of the two yellow slots, but if the modules are tested together memtest always fails at the same place.
I've tried fiddling with the timings to no avail - leaving it on auto gives 5-5-5-18, setting manually 5-5-5-15 (and 9-9-9-28 as suggested by OcUK support) makes no difference.
I'm at a total loss - anyone got any suggestions before I throw it out the window?
Cheers!
Steve.
Cheers!
Steve.
