Annoying mouse sensitivity problem
12 Jun 2003
Annoying logitech G5 sensitivity problem
Had this problem for ages now, for some reason when i install the setpoint drivers for my G5 the sensitivity will increase upon rebooting after install or when i open up the setpoint control panel.
Doesn't matter what setpoint drivers i use
Ive tried using setpoint and os implementation, also used the cpl mouse fix to completly disable accel
It resets when i close, then reopen setpoint then press ok. Pressing cancel or closing the window puts it high again
I would just dump setpoint entirely as nothing more than bloaterware and use the generic windows driver. Hope you find that helpful, you still have the high medium and low button on mouse should be enough normally for sniping or whatever.
