I've had this tv for a number of months now so it's well and truly bedded in and while the picture quality is excellent it doesn't seem to handle motion well at all which was the main reason I went for a plasma this time.
The problem is most noticeable when a scene is panning as it'll be jerky and fairly blurred, then when the panning stops the picture will be okay. In addition whatever is moving on the screen will be a bit blurred and hard to focus on.
I've tried messing with all of the settings in the menus and nothing seems to make a difference.
The source doesn't seem to make a difference and the symptoms show whether viewing video or playing a game on the PS3. The main sources I use are PS3, Virgin Media Tivo and streaming across my network direct to the tv.
Has anyone experienced similar with their Panny and if so how did you fix it?
