So for a while now I've been experiencing seemingly random resets of the PC and I can't figure out what it is or what to do. It does seem to only happen when I'm running a game. The game will freeze for a minute and either resume or the PC will blue screen.
The error report thing (thought I'd try it for once) says this...
So that points to the video card, an Nvidia Geforce 7800 GTX.
They then go on to suggest 3 courses of action. Update drivers, done. Manually reduce hardware acceleration, not done, seems like that would defeat the point of having it? Replace the card, no intention of doing.
I'm wondering maybe if it's anything to do with my processor, a 4400 dual core. I've noticed recently as well as the crashes that doing cpu intensive stuff like encoding a dvd brings the pc to a stutter. That never used to happen on a non-HT pentium 4 so I can't see why it should happen now.
Is it possible that's the problem and not my video card? Don't really like the prospect of having to replace either, but is there anything I should have for my processor, fixes, patches etc?
Error type: Windows stop error (A message appears on a blue screen with error code information)
Solution available? Yes
What does this error mean? You received this message because a device driver installed on your computer caused the Windows operating system to stop unexpectedly. This type of error is referred to as a "stop error." A stop error requires you to restart your computer.
Cause: A video adapter device driver
Computer symptoms: A message appears on a blue screen with error code information:
STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER
- or -
STOP: 0x100000EA THREAD_STUCK_IN_DEVICE_DRIVER_M
