Annoying problem
12 Aug 2008
if i try to connect the graphics card whilst motherboards screwed into case, only half of it will connect in the slot properly, its like the fact that its screwed down isnt aligned right with the case, but if i take out the motherboard and try to connect the graphics card, it fits perfectly :S:confused::confused:
ideas?
