Ok I origonally bought two identicle PC's so some may remember problems I had before. However my wifes PC is just as bad as mine used to be.
Problem 1) Plug in a Ipod - PC locks up solid.
Problem 2) Try to update Nvidia drivers - Get an error.
Oh and on a related issue - anyone know if there's a Ram speed divider on these system as Project RedAlert uses the same board and is becoming Ram Limited.
Full system spec :-
X2 3800+ running at stock speed.
Abit Fatality AN8 SLI mobo.
X800GTO2 Running stock ( not even unlocked)
2gig Geil Value Ram
Windows 2000 SP4
I re-installed Windows 2000 from scratch, installed SMBus/Network/Sound and Graphics drivers. Did Windows update to beyond SP4 and installed DX9c. Then tried both of the above ( the ipod and the driver update ) neither worked. So the problem is NOT a windows install/config issue, it seems
consistant accross Abit boards and a fresh re-install didn't fix it. Oh and she's running the latest BIOS for the mobo.
I can see another ASus board being purchased as these run fine unlike the Junk that is the Fatality :/ (wish I'd listened to you guys *sob* when I bought it)
Full system spec :-
2gig Geil Value Ram
Windows 2000 SP4
