Hi all. I have a forum board set up and the forum location is at
www.mysite.org/forum and in the VB settings this is listed as such!
On the site home page www.mysite.org is a 'click logo to enter' jobbie and when you hover over the logo, in the bottom left the direct is www.mysite.org/forum
GREAT!...............however, when you click it, it takes you to www.mysite.tsohost.co.uk/forum
Now, if I navigate around the forum board, search function, register, etc, the address always stays as www.mysite.tsohost.co.uk/forum/whatever...
But, if I click in the address bar and remove the '.tsohost.co.uk' part and replace it with '.org' (effectively reading www.mysite.org/forum) everything works as I want it and navigating from here, the address bar remains the same i.e. www.mysite.org/forum/faq.php (or whatever)
Basically, how or what do i need to do so that when i link from the site the address bar always shows www.mysite.org/forum and not the tsohost stuff!?
Does this effectively mean that i'm running duplicate pages!?
Thanks
Thanks
I had same problem
