Annoying spyware popup
4 Sep 2005
London
Hi all
Can someone identify what this spyware is? And how to get rid of it
It links to a website called Spyfalcon
Hi All,
I have just built a new rig, which seems to be getting attacked from all sides even though I have a firewall and antivirus installed.
I have this SpyFalcon adware problem. Have followed the instructions to remove but still each time I reboot and go to Internet explorer I get ack to the SpyFalcon website?
Any idea how to remove it from IE?
I take it you have reset your homepage in IE?
Also try running Spybot S&D/ Ad-Aware past the machine and see if they can remove anything.
-Leezer-
-Leezer-
Yes, have reset IE, at least changed the default site, but it always returns. Will try above utilities.
No probs ;)
If this persists though, you might want to take it somewhere with a dedicated anti-malware section (Castlecops/ Major Geeks)- They should be able to help you more quickly & easily.
-Leezer-
