annoying white space issue
12 Feb 2006
Surrey
ok this has just bugged me for the last time so i will be finding a solution to it so i can finally say hasta la vista baby to it once and for all.
when i am writing away i like to add white space to my code to keep it neat, however white space in code sometimes adds white space on the page, e.g.
Code:
<form action=''>
   <label for='field1'>Search our Site</label>
     <input type='text' class='field1' id='field1' name='keyword'/>
     <input type='submit' class='field2' value='search' />
</form>
this will be displayed with a space between the input text field and the submit button. annoyingly i will forget this and spend far too long looking why there is a 2px margin between the fields, to eventually remember it's because there is a space in the code.
how can i stop this from happening in the future? i want to have the white space to keep the code neat and i am sure i will be doing it again any way so i really will be so grateful to whoever gives me the answer :)
thank you
Generally you can't.....down to the point that IE6 sometimes puts spacing inbetween list elements unless you put the <li> and </li>s next to each other.
CSS for the input element:
display: inline;
works doesn't it? (been a while so I may be wrong...)
Well form inputs are inline anyway, so surely display:inline is redundant?
Personally, if I were you I wouldn't style forms like that. I find you get much more control if you wrap elements (and labels if you're using them) in block-level elements such as <li>, <p> or <div>. This, coupled with the fact that XHTML strict denotes that you can't place an inline element directly inside a form tag, makes styling much easier.
Maybe IE6 is causing problems because you're putting it into quirksmode by contravening strict guidelines? That's just a guess but you never know.
i haven't even looked to see if this problem is in ie6, i assume it is but it's also in firefox3 so very annoying. how would wrapping the elements in block level elements help?
they are already wrapped inside a div, i then want the label, search box, and search button all to appear on one line (e.g. this search bar but without any space between the elements) so i would have thought inline without floating is the best way? it just means that the white space is being shown
Make sure your editor is using tabs instead of spaces for indentation when writing markup. Generally using spaces is much more preferable for programming code, but for markup it introduces a number of problems.
Tabbed whitespace is fully collapsed by browsers when rendered, while spaces are only collapsed down to a single whitespace character.
ah maybe this is it then. i'm using notepad++ so how would i find out if it's using tabs and not spaces?
not sure if it makes a difference when the show all characters button is selected there is CR and LF between any element on a new line, not sure what they mean though, guessing clear left?
CR = "Carriage Return" or \r
LF = "Line Feed" or \n
These are just the new-line characters and are perfectly fine. Windows uses \r\n, and nix uses \n.
I'm not sure about configuring Notepad++.
