Annoying XP Style Problem!
10 Dec 2003
I recently installed StyleXP and downloaded some themes for Windows XP to spice things up a little. I downloaded one and it said something about needing to install the included font file (Lucida Grande) for the theme. So I did.
I then installed the theme, didn't like it all that much and put my old one back on, but it kept the font for the style I had just tried out. So it ruined it. This font applies itself to all styles, even when it isn't part of them. The only time I can restore to the windows default font is if I use the default skin, which is just gross and boring.
This font changes all the writing over all the system. MSN Contact list, application toolbars, start menu, window titles. Everything. I can't get rid of it. I tried deleting it but it said it's being 'used' and thus, can't be deleted. As I guessed it would do.
Any ideas? It's really annoying me.
StyleXP seems to cause a lot of problems. You're generally better off just using the themeui patcher and applying visual styles from the Windows display properties bit.
