If anyone could help me, it would be great. My case is nothing special, im not even sure what the make is but thats not too important I dont think because my problem is probably common enough with any case from time to time.
Basically I get an infuriating whirring noise every couple of seconds. Other than the whirring its a really quiet build. It generally goes like this:
...wwwhhhiiiiRRRRRRRRRRrrrrrr........wwwhhhiiiiRRRRRRRRRRrrrrrr...... repeat forever.
Its not quite a noticable with the case sides and top off but its still there. Should I tighten the screws, loosen the screws? Any ideas would be great!
Thanks!
