Hello everyone, a little advice please, as I,m a bit simple!
This is my first half decent rig..
A8n-e Wd160 sata X2 3800+ 6600gt
Currently have 1g of ram installed (although I don,t know what make etc)
During what I think is called the POST it reads
1024 single channel 333.
I am just getting into video editing, so assume that more/better/faster memory will benefit me.
I have done searches on here, but there is so much I get cunfused!
I am using Asus, software o/c prog, AiBooster, and running at 2.2g, (on auto).
Budget not really an issue, but I would like to think under £300
Could you suggest any 2g kits that would be suitable pls.
Last thing, upon installing diffent memory (or before) would I need to put any settings, such as the AiBooster back to original default values?
Thanks a load. Russ.
See if there is an option set to AUTO in the memory area of the BIOS for a Divider or Ratio and see if its set to 1:1 (perhaps its because of the AiBooster). This should make the RAM run at 400Mhz in line with the CPU.
