TaKeN said:I couldnt get mine to run above 2.6 on stock volts
Amps said:very good on stock volts. very good indeed.
What is the stock volts on that chip 1.35 - 1.4v?
TaKeN said:I dont understand how to use prime 95 lol, i think i might need some help later please![]()
I prefer to test the cpu using Counter Strike Source for a few hours![]()
If its unstable, it ALWAYS Crashes...
TaKeN said:Thanks man![]()
Im gonna run prime 95 overnight and make sure she's stable.
Is 1.6 Volts ok, as long as temps are below 50oc ?
TaKeN said:ive got a friend who got a CAB3E its a real shame though... cause its sitting in a mobo at stock speeds![]()
I had mine running at 2.8 Ghz all last night playing Counter Strike Source for hours, seems to be very stable![]()
Hesky82 said:monaco87, is it a KAB3E stepping 3700+? i bet it is, a friend got his to 3.2ghz on "cold" water, they have the cold bug though. not quite as flexible as an opty but still one of the best cheap single core athlons steppings so far.
