Hi there
Were now taking pre-orders on DELL's 4K Display, with stock due in a week or so and our price is very good in the market.
Dell UltraSharp UP3214Q 31.5" Widescreen LED 4K Monitor - Midnight Black @ £2,299.99 inc VAT
See your work in stunning Ultra HD clarity on our largest DellTM UltraSharp monitor featuring high pixel density and exceptional color accuracy.
Whether it’s video editing, CGI animation or application and game development, the Dell UltraSharp 32 Monitor – UP3214Q lets you hone in on the fine details and give your work the attention it deserves. Featuring PremierColor, the UP3214Q offers superb color accuracy and high-end professional features.
Features:-
- Ultra HD 3840 x 2160: Get four times the resolution of Full HD and see the finest details with ultra-high pixel density.
- Vivid, accurate and consistent color: With PremierColor, your monitor provides superb color accuracy and 99% AdobeRGB and 100% sRGB coverage.
- Expansive display: Multitask with plenty of space to see all of your applications across an expansive 31.5" display.
- See more in Ultra HD 3840 x 2160. That’s four times the resolution of Full HD.
- With extremely high pixel density, the tiniest details in videos and images are revealed, providing a whole new level of clarity.
- Do more with a 31.5" screen, giving you ample space to open multiple applications.
- Get a clear and consistent view with an ultra-wide 176°/176° viewing angle.
- Keep your virtual workspace tidy with the Dell Display Manager’s Easy Arrange feature that lets you neatly display windows side by side.
Specification:-
- Diagonally Viewable Size: 80.1 cm
- 31.5" (31.5-inch wide viewable image size): Aspect Ratio:
- Widescreen: 16:9
- Panel Type, Surface: IGZO LCD, In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 3840 x 2160 at 60 Hz (DP1.2*), 3840 x 2160 at 30Hz HDMI
- Contrast Ratio: 1000: 1 (typical)
- 2 Million:1 (Max) (Dynamic Contrast Ratio)
- Brightness: 350 cd/m2 (typical)
- Response Time: 8 ms (gray to gray)
- Viewing Angle: (176° vertical / 176° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100%, 1.074 Billion colors (10 Bits)
- Pixel Pitch: 0.182 mm
- Pixel Per Inch (PPI): 140
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Connectivity: 1x HDMI connector, 1x Mini DisplayPort, 1x DisplayPort (version 1.2a), 4x USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream
- 1x Media Card Reader
- Stand: Height-adjustable stand, tilt, swivel and built in cable-management
- Flat Panel Mount Interface: VESA (100 mm)
- Dimensions with stand (H x W x D): 19.0" ~22.5" (482.6 mm ~ 572.4 mm) x 29.5" (749.9 mm) x 8.4" (214.0 mm)
- Dimensions without stand (H x W x D): 17.5" (444.6 mm) x 29.5" (749.9 mm) x 2.0" (51.5 mm)
- Warranty: 3yr
Only £2,299.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Widescreen: 16:9
- Warranty: 3yr
ORDER NOW
