**** Another Amazing Case Deal ****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
WHAT A BLOODY SILLY, SILLY PRICE!
Zalman Z9 Plus Tower Case with Fan Controller - Black @ £40.99 inc VAT
The latest offering from Zalman is the Z9 Plus which offers amazing value and great features. This chassis is a must for any new build. Regulating your interior temperature has never been so simple: as the Z9 Plus includes a built in fan controller and LED temperature sensor allowing you to fine tune your cooling. The Z9 comes equipped with a well designed side window to showcase all your components and allow further cooling with its semi-mesh design.
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
Was £52.99 Inc. VAT
Only £40.99 inc VAT.
ORDER NOW
This has made me happy, this was the case i was just about to order for my first build! good job I didn't order last night!
excellent stuff....but i don't get it....caseking never does such great offers and it's actually ok's owner, why is that?
Cos I'm the best case buyer around! I work harder than CK do, to provide customer with excellent deals, clearly :)
Here is a little build log of the case I did a few days back!
I've had the case for about a month now, it is fantastic!
http://voxelcast.com/index.php/maxis-blog/32-new-pc-case
The cable management is so easy! I'm terrible at stuff like that but everything just seemed to fit perfectly, the only tricky part was getting some of the fan cables hooked up to the motherboard due to my massive cooler being in the way. More pictures in the above link including some good before/after shots, due to the cable management and airflow it did actually bring my temps down 2-5 Degrees :D
