another, are my temps ok? thread
17 Jul 2009
at home, you?
specs are
i5 2500k @ 4.3ghz
1600mhz xms 4gb
arctic cooler pro 7
temps on idle are
core #0: 42c
core #1: 44c
core #2: 47c
core #3: 39c
any help would be appreciated
Load temps are the ones that matter.
This. On my setup (completely different CPU etc) my CPU idles at 45-50c but only loads at 60 odd due to the fan profile I've set in BIOS. I'd prefer silence while working/browsing with a higher temp and couldn't give a hoot about a bit of fan noise when gaming :)
Load it up with IBT or Prime95 and post your temps after 10 minutes or so
under maximum load they go between 72c-75c on cores 0 1 and 3 but core 2 goes to about 81-83 using intel burn test on maximum setting, i made a record of my last run the other day
