another BSOD which was process_has_locked_pages
8 Oct 2006
hi,
all i did was to try join a online game of Armed Assault and game froze, ctrl alt del out and taskbar said game had stopped responding so i closed it down and then BSOD
im using vista 64bit
6700 core duo
680i sli evga motherboard
2gb ocz sli ram
g/force 8800 768mb
any ideas whats at fault.
apart from h/w failure (and I'd look at psu first), maybe you're looking at s/w failure - drivers (network/graphics/etc), or application (are you running beta at all?). do you get failures on any other games or applications. have you run an orthos blend test (hopefully unlikely if you're not o/c) to rule out your own system? hth :) .
have you got a link to orthos blend test program for vista 64bit please or anyone.
many thanks.
ive done a memtest for 8 hrs with no faults so i guess that counts the ram out.
google for orthos_exe_20060420.cab you should find a source.
btw, if you can take 8 hours of memtest - I'd be thinking drivers rather than system at this point. check for any game patches, and sound and graphic driver updates. hth :) .
sorry, dunno what happened there, try c+p:
http : // forums .
h e x u s .
net /
showthread .
php
t
103676
edit: pls. remove the spaces and line-breaks - wouldn't post for me otherwise
