Another build check for an old man please
29 Oct 2002
Kent
Well as title says, I have been waiting months for Conroe and looking at my A64 3200 and Galaxy 6800GT struggle with my Dell 2405fpw. Budget 1500 quid tops, games machine :D
So, I have the following spec ready to go, this will be my second build and basically I want to make sure it all works and is compatible :eek:
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache - OEM (HD-069-WD)
Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - OEM (HD-070-WD)
HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-HT)
Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
Seasonic S12 600W Silent ATX2.0 Power Supply (CA-002-SS)
Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) (CA-054-LL)
Lian-Li PC-60/PC-7 Window Side Panel - Black (CA-063-LL)
Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) (CD-078-SA)
Western Digital Secure Connect Serial ATA Cable (CB-000-WD) x2
OcUK Value Floppy Drive - Black (HD-001-OK)
Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin (FG-024-AK)
Akasa Rounded Floppy Cable (0.45m) - Black (CB-031-GE)
There is nothing worse than getting a system and finding your missing an item or something isn’t compatible so my quickfire question and observation list is…drum roll….
Will I need any 3-4 pin convertors anywhere?
Ill bung the operating system and games on the Raptor and everything else on the 'big drive'
Will the Amber fan suffice for this case cooling wise, not sure of the layout as some say it has 2 120mm fans?
Ive gone for an XT rather than an XTX, at least save a little money for little performance gain
Shall I be safe and buy a 30 quid celeron in case I have to flash the BIOS on this mobo?
The Samsung DVD-RW I have no idea about – they all seem pretty much the same and I picked it as I have a Samsung phone, any others that are better performance or reliability?
Do I need to buy some Arctic compound for the Ninja and will it fit the case?
Shall I get a Silverstone TJ03 instead of the PC7 – seems a lot of extra money for the TJ03 for little gain?
Ok, sorry for the long list but I want to get this right first time, can’t wait to see the difference from my old system, exciting days! :)
thanks for any comments etc
Am
About to order!
Cheers, ive changed the drive to the one you mention...
ok finger hovering over the 'order' button, ill give it an hour before I commit ;)
bah just noticed PC7 has gone out of stock 1-3 days...lol typical (its a sign...)
or change it to a V1100 instead...
Oc shipp's with sorted Bios now :) no need for extra celeron
cooler should have paste on it rdy 2 fit
I wouldn't bother with a Raptor as the new Seagate 7200.10s are nearly as fast, quieter, cooler, larger, and cheaper. Perpendicular recording does make a big difference in speed.
Another vote for the 7200.10's. Fantastic drives.
