- 19 Jan 2008
- United Kingdom
I purchased a £5 unbranded card reader from ****** last year which worked fine. It plugged into the USB header of my motherboard. When I upgraded my PC (including motherboard) and reinstalled Windows 7 fresh, I could not get the card reader to work. The USB function worked but the actual card reading ability failed to function. Device manager tells me it's a driver issue. ****** were unhelpful and said this card reader isn't supported in Windows 7, so there is nothing they can do.
I decided to purcahse a more expensive card reader from Overclockers.co.uk. This time, I wanted it to be a well known brand so I selected this Akasa card reader (which is Windows 7 compatible) The Akasa product page is here. This card reader only requires connection to the motherboard via USB header (like my previous card reader). It lights up but windows cannot find a driver for it. The manual says it will work out of the box for all functions with exception of the smart card and SIM reader.
I've visited Akasa website and downloaded the latest drivers to see if that helps but it doesn't do anything, just installs the SIM edit software. I have also installed from the mini-disc but again, all it appears to do is install the SIM edit software. I've been to device manager and changed the unknown device to "USB Composite" but this has not helped, I still get a yellow exclamation mark. I've also gone to Windows update but it didn't help. Furthermore, I have plugged the card reader into another USB header but again, this has not helped.
Now two card readers have failed to work so I am wondering if it's something to do with the UEFI settings? My motherboard is an Asrock Z68 Extreme4
