looking to mod an old case, my plans are:
im not sure what colour lights to go, i either want UV, Purple or Green.
if i go ...
...green then i will possibly change my side fans (ambers) with green LED ones, put a clear one on the front and another LED at the back, along with 1 pair of 12" green neons and 1 pair of 4" neons for under glow effect on the front.
...purple i may not change side fans if i do they will have to be clear, clear one on the front and back, and have 1 pair of 12" purple and 1 pair of 4" purple
...UV i will change side fans to UV and get UV front and back, obviously neons will be UV
but only 1 pair of 12".
any thoughts or suggestions?![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
- front mounted 120mm fan where 4 80mm are meant to go
- enlarge a 60mm slot to take a 80mm fan
- stick some neons in it
- maybe cheap water cooling (not sure though)
if i go ...
![Stick Out Tongue :P :P](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
