hey all,
I writen this code (below) it use's a background worker to run the 2 dos commands and display them to the listbox as they run.
I had it working well but i made one samll change and now it keeps failing.
the error is;
System.Reflection.TargetInvocationException was unhandled
Message="Exception has been thrown by the target of an invocation."
Source="mscorlib"
StackTrace:
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(ApplicationContext context)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
at Helpdesk_support.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
at System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ThreadHelper.ThreadStart()
here's the code. If anyone knows why this is happening please tell me!!!
Public Class menu2
Private WithEvents testworker As System.ComponentModel.BackgroundWorker
Private Sub start_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles start.Click
start.Enabled = False
Btncancel.Enabled = True
statuslist.Items.Clear()
prgthread.Value = 0
prgthread.Maximum = 2
testworker = New System.ComponentModel.BackgroundWorker
testworker.WorkerReportsProgress = True
testworker.WorkerSupportsCancellation = True
testworker.RunWorkerAsync()
End Sub
Private Sub testworker_dowork(ByVal sender As Object, ByVal e As System.ComponentModel.DoWorkEventArgs) Handles testworker.DoWork
Dim value As Integer
For value = 0 To 0
Dim listtext As String
Dim args As String = "/c net use \\crc3 /user:meg_swan\tristan.drinkwater password"
Dim p As New Process()
Dim FileName As String = "cmd"
Dim Arguments As String = args
p.StartInfo.UseShellExecute = False
p.StartInfo.RedirectStandardOutput = True
p.StartInfo.RedirectStandardError = True
p.StartInfo.CreateNoWindow = True
p.StartInfo.FileName = FileName
p.StartInfo.Arguments = Arguments
p.Start()
Dim output1 As IO.StreamReader = p.StandardOutput
While (Not output1.EndOfStream)
listtext = String.Concat(output1.ReadLine)
testworker.ReportProgress(value, listtext)
End While
If testworker.CancellationPending Then
Exit Sub
End If
'Threading.Thread.Sleep(10 * 100)
Next
GoTo lable1
lable1:
Dim value1 As Integer
For value1 = 0 To 0
Dim listtext1 As String
Dim args1 As String = "/c copy c:\test.txt \\crc3\c$\nice10.txt"
Dim FileName1 As String = "cmd"
Dim Arguments1 As String = args1
p.StartInfo.FileName = FileName1
p.StartInfo.Arguments = Arguments1
p.Start()
listtext1 = String.Concat(output1.ReadLine)
testworker.ReportProgress(value1, listtext1)
End While
Exit Sub
End If
Next
End Sub
Private Sub testworker_progresschanged(ByVal sender As Object, ByVal e As System.ComponentModel.ProgressChangedEventArgs) Handles testworker.ProgressChanged
prgthread.Value = prgthread.Value + 1
statuslist.Items.Add(e.UserState)
End Sub
Private Sub btnCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Btncancel.Click
testworker.CancelAsync()
prgthread.Value = 0
End Sub
Private Sub testworker_runworkercompleted(ByVal sender As Object, ByVal e As System.ComponentModel.RunWorkerCompletedEventArgs) Handles testworker.RunWorkerCompleted
start.Enabled = True
Btncancel.Enabled = False
End Sub
End Class
cheers guys!
the error is;
Source="mscorlib"
StackTrace:
Public Class menu2
prgthread.Value = 0
End Sub
For value = 0 To 0
p.Start()
End While
Exit Sub
End If
Next
GoTo lable1
lable1:
For value1 = 0 To 0
p.Start()
End While
Exit Sub
End If
Next
End Sub
End Sub
prgthread.Value = 0
End Sub
End Sub
End Class
cheers guys!
