Another CPU Cooler for S775 (E8400)
16 Oct 2008
I have an older Asus P5E3 Premium matched with a E8400 (not O/C) and right now is being cooled via a Zalman CNPS7700-AlCu I was wonder what people would suggest to bring the noise down right now it will be going into a Fractal Design Refine XL so room might be tight at the top of the case, budget is £50 will go for more if i HAVE to but would prefer not too.
All1
budget
try this one for £24 the Alpenföhn Triglav http://www.overclockers.co.uk/showproduct.php?prodid=hs-030-al
or gelid tranquilo
mid to high range
the venomous x £42 http://www.overclockers.co.uk/showproduct.php?prodid=hs-093-tr&groupid=701&catid=57&subcat=1395
or super high end
for £60 the phanteks ph-tc14pe which is one of the best air coolers you can buy.
http://www.overclockers.co.uk/showproduct.php?prodid=hs-003-pt&groupid=701&catid=57&subcat=1395
cpu cooler review here by helios1234 http://www.vortez.net/articles_pages/phanteks_ph_tc14cs_cpu_cooler_review,11.html
edit.
Maximum CPU cooler height: Supports CPU coolers with height of 180mm
http://www.legitreviews.com/article/1782/1/
