- 9 Mar 2008
Sorry for another degradation thread, but i think i may be experiencing something similar to Vertigo1. I've had a Q6600 since last July which is showing signs of being unstable. When i first got the processor, i clocked it to 3.3 Ghz with a vcore of about 1.35-1.37 i think (VID 1.325). I had quite a few stability issues a few months later and concluded that it probably wasnt all that stable, so using LinX (Linpack stress tester) i got it stable using 1.4v vcore. It has sat at this setting since late november or early december.
Recently has shown signs that i cannot hold the clock - i have been getting a few BSODs, so last night i ran the OCCT large memory stress test for an hour, and it passed fine, as did a 3hr run of memtest, but LinX would not run stably. I have bumped the vcore up a few notches (from reading around, vcore is the likely suspect for Linpack failures) and will see if this improves things. I'll also try and run a long prime lend test. However, i do think its strange that it can no longer hold the clock. It has been running Folding@home for at least 6 hours a day since December, and when its on its at 100% load and has shown no signs of instability (temps also never get above about 59C). What are people's opinions - does it look like the chip is dying?
I've noted my BIOS settings in case there is something obvious i should change. Im not that experienced at overclocking, but from reading around my settings seemed fine:
ASUS P5Q Deluxe Motherboard
Q6600: 367x9
vCore: 1.4000
PLL: 1.52
FSB Termination: 1.24
NB: 1.20
Memory: 1104 Mhz (Corsair Dominator pc8500 RAM), 5-5-5-15 timings, PL of 8, everything other timing on AUTO
Memory Voltage: 2.12
Everything else (Southbridge, GTL etc has been left on AUTO). As i say, it seemed fine until a few days ago, but now is a little flakey...
Cheers, any help is appreciated. If it would be easier to have this in the other thread, i'll close the thread and move it, but i dont want to clog up Vertigo's thread!
Q6600: 367x9
vCore: 1.4000
PLL: 1.52
NB: 1.20
