Another CS:S Problem :\
4 Sep 2005
London
Hey all
Basically Fraps + CS:S dont like each other. If i run them both at the same time, CS:S will just bounce back to desktop when i try and load it up :confused:
However its fine when fraps isnt running :(
Anyone know whats up?
Cheers
ScarySquirrel said:
I used to have this problem, went away when i upgraded my CPU and GFX card a while back. Maybe your system is under too much stress while recording
But i wasnt even recording.. i'm just running fraps in the background and when cs:s loads up (not even in a game) it crashes back to desktop
m3csl2004 said:
id sugest changing your graphics drivers but tbh it may be more hassle then its worth
yeh.. i probably get a really bad frame rate recording anyway.. ah well
Is the game still running minimised? there is a problem with source minimising itself, something to do with refresh rate iirc
there is a command in source that allows you to record a series of screenshots then convert them to AVI using VirtualDub. If thats what your after.
EDIT: try cl_avidemo "XX" (XX being your desired framerate 30 should be ok)
EDIT: w00t 100th post :D
