Another Custom loop Question
6 Dec 2013
Hey All,
I have a new custom loop being fitted next weekend and I am fairly ok with how everything is going to fit apart from how many fans to fit to the 360 and 240 radiators as I have seen some builds where people have put fans on the top and bottom of the radiators and then other builds that have fans on just one side.
Is it better to have more if you can afford to put fans on both sides I assume one side of fans pushing cold air onto the radiator and one side sucking the heat from the radiator or is this not how it works.
Any advice on how the fan side of things work with the custom loop would be great.
Cheers
Glacious
Well thats that then Ill stick to 5 for the Radiators then :) Just to decide on the flow now yawn thats gonna confuse my small brain lol
