Another DOA4 Question
15 Aug 2003
Essex
Im doing sparing mode at the moment, and quite often now when i get to the big throw combos i notice it has a small dot between moves
what does that actually mean? i assumed it means during the first throw
i,e
<-Throw * ->Throw
would be perform the first throw, during perform the second.
im trying to do Ryu's Izona-Ogani throw, which if u look is hard
its like
halfcircle+throw * halfcircle+throw * threquarter circle+throw
i can do the first bit fine, and have fluked the 2nd bit a few times..but without knowing what the dot means im a bit puzzled
the dot means that you have to wait til the end of that throw if I remember correctly.
I had a move like that for Tina (that is the American female?) where you had to thrown them down and then spin them round which was done by doing one throw and then the other
YAY i just did it out of luck i just contantly span the left thumb stick and tapping jump...
now im stuck on another move... this guy has some complex combos!!!
It just means pause, you can't just do the combo all at once like the punching combos. The pause you need isn't that long just take it slower and think about getting the stick rotation just right.
EDIT: I took a bit long typing that :p .
Lol, this tends to be how I do some of the more complex moves; which doesn't bode well for pulling them off in the heat of battle ;)
Ryu Hayabusa a.k.a Ninja Gaiden
/edit
stuck on 86 of 100 now, gotta do a complex combo :s can kinda do the first to steps but 3/4 circle and X i just can do
