Another DS3 Overclocking Thread
7 Feb 2004
North East
Hi ...
Im not a n00b, but i am an intel / DDR2 noob :p ...
I have adjusted voltages, PCI-E lock @ 100, increased FSB, turned off the speed control thing, and am stuck ataround 380 fsb ... any tips or anything else to turn off ?
Thanks for all help...
Temps are good - 34 load cpu, 38 load nb temp :)
EDIT - not stable, backed down to 350 , am on the F4C bios
Try the official F4 BIOS from here Also read through this to see what other people have disabled in their BIOS to get over 400Mhz.
Ive seen a f5 bios floating about but its a beta,im running the f4e at the moment very stable and it sorted a lot of problems i had with the f3 bios.
The official F4 is newer than F4e.
What memory timings are you using or are they still set to auto ?(Ctrl+F1 on main Bios screen to get extra settings in M.I.T. menu) Have you set memory multiplier to 2 ?
yep, @ 2 ... 4 5 5 timings (stock timings for the ram at 400 (800) )
clone said:
whacked both to +0.3v , vdimm at +0.4v
Are those volts safe to use?
you wont ever have a problem with the allowed voltages bar the ram and cpu, which you have to suit to your chips and cooling :)
plus my chipset is watercooled, not breaking a sweat atm ;)
