Another first time water-cooler!!
17 Nov 2011
Timbucktoo
Hi guys. Tomorrow I am ordering all my components for my new build. The case I am going to use is the CM Storm Stryker.
Now for a roof mounted kit I was planning on using the XSPC Raystorm 750 RS240 watercooling kit. For the bottom Rad set-up I am a little confused as to what to get.
I also want a 240 there, but can use the bottom in a push/pull configuration as there is enough room (there isn't enough room at the top for push pull without modifying the case).
All I plan to do is cool the CPU and GPU.
Any suggestions would be most welcome. Thanks, Dave.
