another for a m8! help pls
17 Aug 2005
Gloucester, UK
ok well christmas is over and a m8 wants an upgrade. heres what i think so far,
now would a Tagen 580 psu run this, or does he need another?
also i chose the sythe ninja, but the titan armada looks better, would there be a big difference?
Team Xtreem 2GB (2 x 1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit (TXDD2048M800HC4DC) £174.99
(£205.61) £174.99
(£205.61)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £171.99
(£202.09) £171.99
(£202.09)
EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard £154.99
(£182.11) £154.99
(£182.11)
Arctic Silver 5 Thermal Compound (3.5g) £5.99
(£7.04) £5.99
(£7.04)
BFG GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £339.99
(£399.49) £339.99
(£399.49)
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler (478/754/939/940/AM2/LGA755) £29.99
(£35.24) £29.99
(£35.24)
Western Digital Raptor X 150GB WD1500AHFD 10,000RPM SATA 16MB Cache - OEM £132.99
(£156.26) £132.99
(£156.26)
Sub Total : £1,010.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
Vat : £178.48
Total : £1,198.36
hows that look, anything you would change?
Very nice, looks impressive that setup. He will be happy. What are the rails like on the Tagan, specially the 12V. He will need strong ones for the 8 series, its often overlooked. Just before you purcahse your stuff have a look!
As said the PSU should be fine and the rest looks pretty good, one question though, why the Raptor X? Does you mate have a case whereby he can appreciate the clear top? If not I'd get the 'ordinary' Raptor since it is cheaper and has double the MTBF (not that you are likely to get close to the MTBF anyway). :)
ok small update, his wife gave him a nice 800 towards it , so here is the revised. how does this look :
(£205.61) £174.99
(£205.61)
(£182.11) £154.99
(£182.11)
(£7.04) £5.99
(£7.04)
(£399.49) £339.99
(£399.49)
(£156.26) £132.99
(£156.26)
Titan Amanda TTC-NP04TZ TEC & Heatpipe Cooling Fan (Socket 775) £55.99
(£65.79) £55.99
(£65.79)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM £56.99
(£66.96) £113.98
(£133.92)
(£202.09) £171.99
(£202.09)
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor - Midnight Grey £449.99
(£528.74) £449.99
(£528.74)
Sub Total : £1,600.90
(This can be changed during checkout) Shipping : £12.95
Vat : £282.42
Total : £1,896.27
Got the Tagan 580w Easycon meself
2x12v Rails 20A each
