Another gamer spec check please!
6 Aug 2006
# Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN) £112.95
# Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK) £53.95
# G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS) £106.95
# Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) £126.95
# Samsung SH-D162 DVD-ROM (Black) - OEM (CD-002-SA) £11.50
# Samsung SH-W163 16x16 DVD±RW Serial ATA Dual Layer ReWriter (Black) (CD-076-SA) £23.95
# Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR) £14.95
# Antec NSK4400 Mini Tower Case - 380W SmartPower PSU (CA-052-AN) £43.95
# Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA) £42.50
#Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01528) (OS-001-MS) £51.95
Total - £589.60
vat - £103.18
Total - £692.78
Are there any issues with this compatibility? It's a wee bitty over my budget, would like to scale down to as close to £600 as possible. Any suggestions on how to do this, without mega comprimise?
Any suggestions for a first timer would be a help!
John
Nelson15 said:
No, I wasn't. I was plainning on upgrading the board a few months down the line once things have started to settle down a little!
Thats an OK stop gap mobo but for 40 quid more you could get A DS3 that will allow higher overclocks.
But if not overclocking it will be fine.
Forgive me if I'm being blind.. But it looks to me like you intend to use the Antec 380W Smart Power PSU that comes with your case? :confused:
One word I can say is "don't". Buy an S12 500W or a Liberty 500W. You need a decent PSU.. Especially with a rig like that.
Definitely ditch the DVD-ROM if money is that tight.
There's not really anywhere else you can cut back, since you already have the worst Conroe chip and a fairly basic case/psu. You could maybe look at dropping to 1gig RAM but you would be crippling the system slightly by doing so.
My advice would be save up for a while longer, and invest a bit extra in a decent motherboard and PSU, and then look at overclocking. That will give you a much better rig in the long run.
