Hi there, I would appreciate some help on choosing a case if you guys would. It will be for an i7 build in the future (but mainly for silencing this noisey tin next to me) most likely using a R2E mobo. The requirements would be to be quiet in general use (aside from using fan controllers) but also have the opportunity to expand into WCing down the line.
I would prefer clean designs. Not the 'gamer' types of HAF, antec 9,12s and so forth. Prices I would prefer would be sub £200 really although can be adjusted depending. I would also prefer a full tower with an aluminium build.
Case will be storing atleast 3 hard-drives for storage also and an SSD.
Cases i've been looking at so far are:
Lian Li A70F - Large, chance for wcing, sleek design. Good cable management opportunities. - cons: top harddrive cages could be too far for PSU (Corsair HX1000), open front (possibly to much noise leakage?)
http://www.lian-li.com/v2/en/product/product06.php?pr_index=337&cl_index=1&sc_index=25&ss_index=61
Lian Li P80 - Huge, great opportunity for watercooling, Sleek (not like haf imo), Cable management opportunities. - cons: expensive, i've also read it can be quite loud.
http://www.lian-li.com/v2/en/product/product06.php?pr_index=131&cl_index=1&sc_index=25&ss_index=61
Coolermaster ATCS840 - Large, again can be watercooled, cable management, cons: plastic parts, flimsy panels (apparantly) and also can be loud with vibration, window is also hard to come by so looks to be a daring mod on myself.
http://www.coolermaster.com/product.php?category_id=18&product_id=5777
TJ07 - Massive, opportunities are great for watercooling and cable management, easily dismanteled - cons: Expensive, requires modding for true potential (just being picky)
http://www.silverstonetek.com/products/p_contents.php?pno=tj07&area=usa
TJ9 / 10 - Seems a good case, made from alu, window, opportunity for WC. cons: the door, mixed reviews on thermal efficiency
http://www.silverstonetek.com/products/p_contents.php?pno=tj10&area=usa
A couple mid-towers have also caught my eyes aswell these being the
Silverstone FT01 - Great air cooling, full alu build, good cable management, black internal, window - Only main problem is mismatched bezel colour to shell.
http://www.silverstonetek.com/products/p_contents.php?pno=FT01&area=usa
Lian Li PC7FNW - Sleek, tidy indented window flush with side, basic cable management, looks to have good storage although restrictive airflow. Very cheap for quality mind.
http://www.lian-li.com/v2/en/product/product06.php?pr_index=393&cl_index=1&sc_index=25&ss_index=62
Lian Li B25F - http://www.lian-li.com/v2/en/product/product06.php?pr_index=366&cl_index=1&sc_index=25&ss_index=62
Seems all require a bit of modding so i'm not really fussed on that front as eventually i'd plan to spray the internals black if required. Any further knowledge and recommendations on these cases will be fully appreticated because i've read that many reviews and such, i'm now more confused than when i started haha.
Kind regards,
Kev.
P.S. sorry for the sheer essay size of this haha
Kind regards,
Kev.
