- 22 Jul 2009
Good evening,
I have a HTPC set-up as below:
Asus E35 M1-M Pro
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz
OCZ 500w Stealth Xstream
OCZ Vertex 30GB SATA-II SSD
WD Caviar Green 2TB
Samsung Blu-Ray drive
Noctua NF-S12B FLX Ultra Quiet 120mm Flexible Cooling Fan x 2
Antec Fusion Remote HTPC case
Runs Ubuntu.
I've had it for about a year and it has a problem that I've lived with.
Whenever a picture pans on the tv the image looses definition/becomes slightly pixilated. It also doesn't play Blu-Ray style MKV files with much success. The film loads but within a few seconds the audio falls out of sync with the video and the video itself starts to stutter and jump.
I've tried different resolutions and the same files/films on my gaming rig, and they play without any issues.
So I'm beginning to think it's a processing (or lack of) problem. Any takers?
I suppose a slightly more powerful system would get over these problems.
Requirements wise, the HTPC:
-must output combined video/audio through HDMI
-must be FULL HD video/audio
-any new motherboard must fit in the case I've got so mini-ITX/etc.
-new system to run Windows 8
-plays movies/music/streams off BBC iplayer and so on. No gaming.
-budget isn't an issue
-system will be connected to the tv through a home theatre amp
I appreciate going for an i7 based system would be a bit excessive so I'm thinking i5, with this motherboard:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-530-AS&groupid=701&catid=5&subcat=2071
This processor:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN&groupid=701&catid=6&subcat=1275
And this cooler:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-027-SY&groupid=701&catid=2330&subcat=2350
Any ideas/tips would be appreciated.
Asus E35 M1-M Pro
WD Caviar Green 2TB
Runs Ubuntu.
This processor:
And this cooler:
