Hi there.
I currently own a system based on a Gigabyte 865PE motherboard
4 2,6Ghz, 1 Gb DDR400 Ram, Radeon 9800 Pro. Do you consider an "adequate" upgrade to hunt for a P4 3,4Ghz (fastest my mobo can take) and also replace graphic card (7800GS comes to mind- i only have AGP)?
Will this cheap upgrade last me for a while? Will i see some difference?
Many thanks in advance
4 2,6Ghz, 1 Gb DDR400 Ram, Radeon 9800 Pro. Do you consider an "adequate" upgrade to hunt for a P4 3,4Ghz (fastest my mobo can take) and also replace graphic card (7800GS comes to mind- i only have AGP)?Will this cheap upgrade last me for a while? Will i see some difference?
Asrock i think) but as you see in my sig , i got 939 and AGP and there are better g/cards (6800GT) in AGP .
